Kirjoittaja Aihe: Talologger Shell modulin konfugurointi  (Luettu 3912 kertaa)
Poissa Kokko74
« : 16.01.22 - klo:21:53 »
Olen yrittänyt tehdä shell modulilla json haun parsimista onnistumatta.
Seuraavalla lausekkeella olen yrittänyt.
@KWHILPO:REGEXP = ^.*"CounterToday"\s*:\s*(?P<Kwh_ilpo>[0-9.\-]+)[,\s].*$
Mutta virhettä pukkaa, olisiko ajatuksia? Pitäisi saada paljas luku jotta ohjelma hyväksyy tuloksen.
KWHILPO: ERROR: Shell data does not match (regexp: ^.*"CounterToday"\s*:\s*(?P<Kwh_ilpo>[0-9.\-]+)[,\s].*$): {
        "ActTime" : 1642361641,
        "AstrTwilightEnd" : "18:29",
        "AstrTwilightStart" : "06:30",
        "CivTwilightEnd" : "16:43",
        "CivTwilightStart" : "08:16",
        "DayLength" : "06:41",
        "NautTwilightEnd" : "17:38",
        "NautTwilightStart" : "07:21",
        "ServerTime" : "2022-01-16 21:34:01",
        "SunAtSouth" : "12:29",
        "Sunrise" : "09:09",
        "Sunset" : "15:50",
        "app_version" : "2021.1 (build 13949)",
        "result" :
                        "AddjMulti" : 1.0,
                        "AddjMulti2" : 1.0,
                        "AddjValue" : 0.0,
                        "AddjValue2" : 0.0,
                        "BatteryLevel" : 255,
                        "Counter" : "1.562 kWh",
                        "CounterToday" : "1.539 kWh",
                        "CustomImage" : 0,
                        "Data" : "1.562 kWh",
                        "Description" : "",
                        "Favorite" : 0,
                        "HardwareDisabled" : false,
                        "HardwareID" : 4,
                        "HardwareName" : "Dummyt",
                        "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
                        "HardwareTypeVal" : 15,
                        "HaveTimeout" : false,
                        "ID" : "82115",
                        "LastUpdate" : "2022-01-16 21:33:57",
                        "Name" : "KWH_ILPO",
                        "Notifications" : "false",
                        "PlanID" : "0",
                        "PlanIDs" :
                                0
                        "Protected" : false,
                        "ShowNotifications" : true,
                        "SignalLevel" : 8,
                        "SubType" : "Counter Incremental",
                        "SwitchTypeVal" : 0,
                        "Timers" : "false",
                        "Type" : "General",
                        "TypeImg" : "counter",
                        "Unit" : 1,
                        "Used" : 1,
                        "ValueQuantity" : "",
                        "ValueUnits" : "",
                        "XOffset" : "0",
                        "YOffset" : "0",
                        "idx" : "115"
        "status" : "OK",
        "title" : "Devices"
Poissa jolla
    • mittauksia
Vs: Talologger Shell modulin konfugurointi
« Vastaus #1 : 17.01.22 - klo:17:03 »
toimii näillä eväillä
taloLogger.conf
@DATASOURCE=SHELL:SHELL1
SHELL1:LOCATION = /usr/bin/cat
SHELL1:PARAMETERS = /home/talo/test.json
@SHELL1:REGEXP = ^.*"CounterToday" : "\s*(?P<Kwh_ilpo>[0-9.\-]+)[,\s].*$
@MEASURE = Kwh_ilpo:SHELL1.Kwh_ilpo
tällaista tulee
  {"toka_anturi":"22.187500"},
  {"kolmas":"23.000000"},
  {"Kwh_ilpo":"1.539"},
  {"LogTime":"17.01.2022 17:02:00"}
