Lämpöpumput => Ekowell => Aiheen aloitti: fkanin - 27.02.09 - klo:19:40
Åre Ekowell pidetään parhaana ja expencive heatpump Suomessa?
Tarkasteltaessa foorumin toiminta on hyvin hiljainen, että Ekowell foorumilla.
Aion rakentaa uusi talo ja etsivät tehokkain tapa lämmön minun lattiat vedellä.
Ekowell vaikuttaa hyvä eritelmät verrattuna muihin pumput. Jokainen on joitakin kommentteja?
En tiedä, onko se mahdollista virka englanti täällä tällä foorumilla niin olen käyttänyt translatetion ohjelma kirjoittaa tällä Suomen.
Feel free to write in english.
I guess atleast some of us will understand your point/questions and we´ll try to give our opinions for you to use.
Anyway, formal english is more understandable than that finnish your translation program is trying to create. Words are ok but the grammar is awfull.
A bit like phrase I feel good would be translated in form feel good I.
Great, thank you!
My question was is Ekowell concidered the best and most expencive heatpump in Finland?
How would you rank the pump compared to Thermia or Nibe?
The Ekowell homepage are not so informative, neither is the dealers I have contacted on email; nobody has answered my mails.
There's several options when ordering a EVT pump.
In example: ZH compressor, class A energi circulation pump, 2nd output for higher bathroom temperature, pre heating to washingmachine (the other options I don't know the english word for).
What does a fully spec EVT500 cost in Finland?
Are there any Ekowell dealers in the forum here?
Or any you recommend I can contact?
The reason I asking for information here is because the pump is not so well known here in Norway or Sweden. And it's very expencive compared to other heatpumps.
Well, it might be the best, but its not the most expencive.
Dont know about Thermia, but Nibe uses mostly old piston type compressors.
The activity in the Ekowell forum here is not so high. In the Lampoassa forum there's a lot more activity.
I have never heared about Lampoassa. Can this be compared to Ekowell's specifications?
It´s better if You call directly to Ekowell factory and try find dealer who is close to area where you are buidling.
It´s hard to say but looklike Ekowell normal style,just same problem when I try buy Ekowell heatpump over 10 years ago.At last I catch one dealer who was very professional solve heatpump plan´s and now my house warming Ekowell pump and hole warming system is working property now over 10 years without any problem.
Possible "Dishwasher" is word.Yes mostly pump´s,also Ekowell have 2 warming circuit,low warming floor and higher is shower and dishwasher etc.Normally higher circuit is between +55C to +65C and modern pump´s can make these water temperatures automatic .
Wellcome to forum ;)
This is great. I know it's many years since you bought your Ekowell, but what was your main reason for choosing this one?
I've tried to email Ekowell, but my request was forwarded to the Norwegian dealer who is expencive I think (EVT500 with all options cost €15000)
Reading this forum I understand a EVT500 costs about €6000 in Finland??
So for the price of one here I can buy two in Finland!! Understand why I'm looking for a dealer now? :-)
I understand Ekowell has one of the best COP on the market. What makes them special compared to other pumps like Thermia, IVT or Nibe?
Thanks! Really glad I could communicate here with the help of Google Translation.
Thanks about Google Translation tip... I can use it for reading the swe forum ;) Seems to be good enough for that job...
when i asked prices from my local dealer, EVT500 cost about 8300e. but because i don't have enough space in my technical systens room, i had to buy smaller ECT500 model what cost's 7730e here in finland.
Number one was silence noise when pump is working,and after 10 years working noise is still same silence.
Pump´s construction look very simple and nice work.
Maybe,,maybe not,its´s many ways to calculate COP.
I think this is littlebit same if ask RR engine power,answer is "it´s enough" :)
Easy way is searching Google "Ekowell myynti" ,there find several dealers and their´s phonennumbers,other contact informations around Finland,if you choose enough many ,call them and ask "best price"
Heatpump dealers http://www.maalampofoorumi.fi/index.php?topic=87.msg422#msg422
Are you building in Finland or somewhere else country?(Sweden,Norway etc).
It´s nessessary that you tell dealer how north you are going to use pump,professional dealer ask you few questions about building,how many people ,swimmingpool etc is going to use pump´s heatpower.
It´s very important choose pump with optional power ,too small or too big not working as economy as optinal.
It´s complicate to choice the best pump because there are so many diffrent types these days,and ofcourse many prices .
Maybe best way if you collect information diffrent dealers,diffrent pumps and when you have enough information to select which one is best to your house,how much it cost,after that select pump.
Please dont look single one mark as Ekowell and close yor eyes other mark´s,and dont look only price.
Optional heatpump choise is not easy,use lot of time to comparison,try find user´s who have same pump working same area and ask their´s experiens pump type what you are thinking.
This could be long an compöicate way but I think about heat pump´s choice is best do this way ;)
Well, that is a very good reason, along with COP, price and easy to install and operate.
If Ekowell is comparable with an RR, you would expect power and good effect.
I', going to build at southwest in Norway. Average outsidetemperature is 8 degrees C.
Not som many have this pump here, probably because of the price and availability, only one dealer.
I really like Ekowell's all-in-one solution. And when this pump also is among the best on the market now, it's really interesting.
I've got in contact with Lampolassa also, they look similar but haven't found any references on these.
I've been looking a this for over a half year now. It's hard to make the right choice. You only gonna buy such a pump one time (i hope).
