	Current outdoor temperature (BT1) [°C]	Supply line (BT2) [°C]	Return line (BT3) [°C]	Hot water charging (BT6) [°C]	Brine in (BT10) [°C]	Brine out (BT11) [°C]	Condenser (BT12) [°C]	Discharge (BT14) [°C]	Suction gas (BT17) [°C]	Average temperature (BT1) [°C]	Flow sensor (BF1) [l/m]	 [°C]	 [°C]	 [°C]	 [°C]	 [°C]	 [°C]	Degree minutes [DM]	Calculated supply climate system 1 [°C]	Power internal additional heat [kW]	Operating mode internal add. heat	Compressor frequency, current [Hz]	Heating medium pump speed (GP1) [%]	Brine pump speed (GP2) [%]	Alarm number	Relay status MCB	Relay status ASB	Priority	Serial number	MCB version	ASB version	Software version	Bootloader version	Secondary bootloader version	Soft on/off version
2023-12-26 19:15:43	-	-	-	-	-	-	-	-	-	-	-	-	-	-	-	-	-	0	15.0	0.0	0	0	0	0	366	0	0	0	06547221025001	0	0	2.23.4	17	17	1.2
