<?xml version="1.0"?>
<V-Control xmlns:vcontrol="http://www.openv.de/vcontrol">
	<unix>
		<config>
			<serial>
				<tty>/dev/vito</tty>
			</serial>
			<net>
				<port>3002</port>
				<allow ip="127.0.0.1" />
				<allow ip="192.168.1.0/24" />
			</net>
			<logging>
				<file>/tmp/vcontrold.log</file>
				<syslog>n</syslog>
				<debug>y</debug>
			</logging>
			<device ID="204B" />
		</config>
	</unix>
	<units>
		<!-- Device list -->
		<unit name="DeviceType">
			<abbrev>DEVTYPE</abbrev>
			<type>enum</type>
			<enum bytes="20 4B" text="Vitocal 333-G ID=204B Protokoll:P300" />
			<enum text="UNKNOWN" />
		</unit>
		<unit name="Serial Number">
			<abbrev>SERIAL</abbrev>
			<type>uint</type>
			<icalc get="((((((((((((B0-48)*10)+(B1-48))*10)+(B2-48))*10)+(B3-48))*10)+(B4-48))*10)+(B5-48))*10)+B6-48" />
		</unit>
        <unit name="SetReturnStatus">
            <abbrev>SR</abbrev>
            <type>enum</type>
            <enum bytes="00" text="OK"/>
            <enum bytes="05" text="SYNC (NOT OK)"/>
            <enum text="OK"/>
        </unit>
		<!-- Relative values -->
		<unit name="Percent">
			<abbrev>PCENT</abbrev>
			<calc get="V" set="V" />
			<type>uchar</type>
			<entity>%</entity>
		</unit>
		<unit name="Percent /2">
			<abbrev>PCENT2</abbrev>
			<calc get="V/2" set="V*2" />
			<type>short</type>
			<entity>%</entity>
		</unit>
		<unit name="Efficiency">
			<abbrev>EFFI</abbrev>
			<calc get="V/10" set="V*10" />
			<type>uchar</type>
			<entity></entity>
		</unit>
		<unit name="Energy">
			<abbrev>ENERGY</abbrev>
			<type>uchar</type>
			<entity>kW</entity>
		</unit>
		<!-- Counters -->
		<unit name="Counter">
			<abbrev>COUNTER</abbrev>
			<type>int</type>
			<entity></entity>
		</unit>
		<unit name="Counter (hours)">
			<abbrev>HOURS</abbrev>
			<calc get="V/3600" set="V*3600" />
			<type>uint</type>
			<entity>h</entity>
		</unit>
		<unit name="Counter (liter)">
			<abbrev>LITERS</abbrev>
			<calc get="V/1000" set="V*1000" />
			<type>int</type>
			<entity>l</entity>
		</unit>
		<!-- Temperatures -->
		<unit name="Temperature /10">
			<abbrev>TEMP10</abbrev>
			<type>short</type>
			<entity>°C</entity>
		</unit>
		<unit name="Temperature /100">
			<abbrev>TEMP100</abbrev>
			<calc get="V/100" set="V*100" />
			<type>short</type>
			<entity>°C</entity>
		</unit>
		<unit name="Temperature /2">
			<abbrev>TEMP2</abbrev>
			<type>char</type>
			<entity>°C</entity>
		</unit>
		<unit name="Temperature unsig /2">
			<abbrev>UTEMP2</abbrev>
			<type>uchar</type>
			<entity>°C</entity>
		</unit>
		<unit name="Temperature unsig">
			<abbrev>UTEMP</abbrev>
			<type>uchar</type>
			<entity>°C</entity>
		</unit>
		<!-- Time units -->
		<unit name="SystemTime">
			<abbrev>SYSTIME</abbrev>
			<type>systime</type>
		</unit>
		<unit name="CycleTime">
			<abbrev>CTIME</abbrev>
			<type>cycletime</type>
		</unit>
		<unit name="Burner Operation Hours">
			<abbrev>BHOURS</abbrev>
			<type>uchar</type>
			<calc get="(B1 * 100)+B0" />
			<entity>h</entity>
		</unit>
		<unit name="Operation Time">
			<abbrev>OPTIME</abbrev>
			<type>uint</type>
			<entity>h</entity>
		</unit>
		<unit name="Operation Hours">
			<abbrev>OPHOURS</abbrev>
			<type>uint</type>
			<entity>h</entity>
		</unit>
		<!-- Status values -->
		<unit name="Plain">
			<abbrev>PLAIN</abbrev>
			<type>short</type>
		</unit>
		<unit name="Status">
			<abbrev>STATUS</abbrev>
			<type>char</type>
			<entity></entity>
		</unit>
		<unit name="ReturnStatus">
			<abbrev>RETSTATUS</abbrev>
			<type>enum</type>
			<enum bytes="00" text="0" />
			<enum bytes="01" text="1" />
			<enum bytes="02" text="UNKNOWN" />
			<enum text="NOT OK" />
		</unit>
		<unit name="On/Off">
			<abbrev>ONOFF</abbrev>
			<type>enum</type>
			<enum bytes="00" text="OFF" />
			<enum bytes="01" text="ON" />
		</unit>
		<unit name="On/Off3K">
			<abbrev>ONOFF3K</abbrev>
			<type>enum</type>
			<enum bytes="01" text="3" />
		</unit>
		<unit name="On/Off6K">
			<abbrev>ONOFF6K</abbrev>
			<type>enum</type>
			<enum bytes="01" text="6" />
		</unit>
		<unit name="SyncStatus">
			<abbrev>SYNCSTATUS</abbrev>
			<type>enum</type>
			<enum bytes="00" text="OK" />
			<enum bytes="05" text="SYNC (NOT OK)" />
		</unit>
		<unit name="Bitstatus">
			<abbrev>BITSTATUS</abbrev>
			<type>uchar</type>
			<icalc get="(B0 &amp; (0x01&lt;&lt;BP))&gt;&gt; BP" />
		</unit>
		<unit name="Internal Pump Status">
			<abbrev>PUMPSTATUS</abbrev>
			<type>enum</type>
			<enum bytes="00" text="Off" />
			<enum bytes="01" text="On" />
			<enum bytes="02" text="UNKNOWN (02)" />
			<enum bytes="03" text="Off" />
		</unit>
		<unit name="Heating Curve Steepness">
			<abbrev>HCURVE</abbrev>
			<type>short</type>
			<entity></entity>
		</unit>
		<unit name="Volumetric Flow">
			<abbrev>VFLOW</abbrev>
			<type>ushort</type>
			<entity>l/h</entity>
		</unit>
		<!-- Operation modes -->
		<unit name="Operation Mode">
			<abbrev>OPMODE</abbrev>
			<type>enum</type>
			<enum bytes="00" text="Standby" />
			<enum bytes="01" text="DHW" />
			<enum bytes="02" text="DHW-heat" />
			<enum bytes="03" text="Unknown" />
			<enum bytes="04" text="Cont-reduced" />
			<enum bytes="05" text="Cont-normal" />
			<enum bytes="06" text="Stan-standby" />
			<enum bytes="07" text="Cooling" />
		</unit>
			<abbrev>SETOPMODE</abbrev>
			<type>uchar</type>
			<enum bytes="0" text="1" />
			<enum bytes="1" text="2" />
			<enum bytes="2" text="3" />
			<enum bytes="3" text="4" />
			<enum bytes="4" text="5" />
			<enum bytes="5" text="6" />
			<enum bytes="6" text="7" />
			<enum bytes="7" text="8" />
		</unit>
		<unit name="Mixer Valve Mode">
			<abbrev>MIXER</abbrev>
			<type>enum</type>
			<enum bytes="00" text="Heating" />
		</unit>
		<unit name="Holiday Mode">
			<abbrev>HOLIDAY</abbrev>
			<type>uchar</type>
			<icalc get="(B7 &amp; (0x01&lt;&lt;BP))&gt;&gt; BP" />
			<enum bytes="00" text="Inactive" />
			<enum bytes="01" text="Active" />
		</unit>
		<!-- Pump type -->
		<unit name="HKP Pump Type">
			<abbrev>HPUMPTYPE</abbrev>
			<type>uchar</type>
			<enum bytes="00" text="Staged" />
			<enum bytes="01" text="Rotational speed controlled" />
		</unit>
		<!-- Errors -->
		<unit name="Error Status">
			<abbrev>ESTATUS</abbrev>
			<type>enum</type>
			<enum bytes="00" text="No error" />
			<enum bytes="01" text="ERROR" />
		</unit>
		<unit name="Error Message">
			<abbrev>EMESG</abbrev>
			<type>errstate</type>
			<enum bytes="00" text="Normal operation (no error)" />
			<enum bytes="0F" text="Maintenance (to reset: Set code address 24 to 0)" />
			<enum bytes="10" text="Short outdoor temperature sensor" />
			<enum bytes="18" text="Interruption outdoor temperature sensor" />
			<enum bytes="19" text="Communication error with wireless outdoor temperature sensor" />
			<enum bytes="1A" text="Communication error on KM-BUS (differential temperature controller)" />
			<enum bytes="1D" text="No connection to flow sensor" />
			<enum bytes="1E" text="Flow sensor defect" />
			<enum bytes="1F" text="Flow sensor defect" />
			<enum bytes="20" text="Short flowline temperature sensor" />
			<enum bytes="21" text="Short return flow temperature sensor" />
			<enum bytes="28" text="Interruption flowline temperature sensor" />
			<enum bytes="29" text="Interruption return flow temperature sensor" />
			<enum bytes="30" text="Short boiler temperature sensor" />
			<enum bytes="38" text="Interruption boiler temperature sensor" />
			<enum bytes="40" text="Short flowline temperature sensor M2" />
			<enum bytes="42" text="Interruption flowline temperature sensor M2" />
			<enum bytes="44" text="Short flowline temperature sensor M3" />
			<enum bytes="48" text="Interruption flowline temperature sensor M3" />
			<enum bytes="4C" text="Interruption flowline temperature sensor M3" />
			<enum bytes="50" text="Short buffer temperature sensor" />
			<enum bytes="51" text="Short warm-water outflow temperature sensor" />
			<enum bytes="58" text="Interruption buffer temperature sensor" />
			<enum bytes="59" text="Interruption warm-water outflow temperature sensor" />
			<enum bytes="60" text="Communication error with fuel cell unit" />
			<enum bytes="61" text="Fuel cell error" />
			<enum bytes="7C" text="Short return flow temperature sensor" />
			<enum bytes="7D" text="Interruption return flow temperature sensor" />
			<enum bytes="7E" text="Short upper buffer temperature sensor" />
			<enum bytes="7F" text="Interruption upper buffer temperature sensor" />
			<enum bytes="80" text="Short lower buffer temperature sensor" />
			<enum bytes="81" text="Interruption lower buffer temperature sensor" />
			<enum bytes="92" text="Solar: Short temperature sensor collector" />
			<enum bytes="93" text="Solar: Short sensor S3" />
			<enum bytes="94" text="Solar: Short buffer temperature sensor" />
			<enum bytes="9A" text="Solar: Interruption temperature sensor collector" />
			<enum bytes="9B" text="Solar: Interruption sensor S3" />
			<enum bytes="9C" text="Solar: Interruption buffer temperature sensor" />
			<enum bytes="9F" text="Solar: Error in solar unit (see solar controller)" />
			<enum bytes="A2" text="Water pressure too low" />
			<enum bytes="A3" text="Exhaust temperature sensor misplaced" />
			<enum bytes="A4" text="Maximum pressure exceeded" />
			<enum bytes="A7" text="Defect of panel" />
			<enum bytes="A8" text="Air in internal circulation pump or minimum volumetric flow not reached" />
			<enum bytes="A9" text="Internal circulation pump blocked" />
			<enum bytes="B0" text="Short exhaust temperature sensor" />
			<enum bytes="B1" text="Communication error with panel" />
			<enum bytes="B4" text="Internal error (electronics)" />
			<enum bytes="B5" text="Internal error (electronics)" />
			<enum bytes="B6" text="Invalid hardware ID (electronics)" />
			<enum bytes="B7" text="Internal error (boiler code plug)" />
			<enum bytes="B8" text="Interruption exhaust temperature sensor" />
			<enum bytes="B9" text="Internal error (repeat data input)" />
			<enum bytes="BA" text="Communication error extension for M2" />
			<enum bytes="BB" text="Communication error extension for M3" />
			<enum bytes="BC" text="Communication error Vitotrol remote M1" />
			<enum bytes="BD" text="Communication error Vitotrol remote M2" />
			<enum bytes="BE" text="Communication error Vitotrol remote M3" />
			<enum bytes="BF" text="Wrong communication module LON" />
			<enum bytes="C1" text="External security device (Boiler cools down)" />
			<enum bytes="C2" text="Communication error with solar controller" />
			<enum bytes="C3" text="Communication error with extension AM1" />
			<enum bytes="C4" text="Communication error with extension Open Therm" />
			<enum bytes="C5" text="Communication error with rotational speed controlled heat circuit pump M1" />
			<enum bytes="C6" text="Communication error with rotational speed controlled heat circuit pump M2" />
			<enum bytes="C7" text="Wrong coding E5 of heat circuit pump" />
			<enum bytes="C9" text="Error reporting contact of switching module V active" />
			<enum bytes="CD" text="Communication error with Vitocom 100 (KM-BUS)" />
			<enum bytes="CE" text="Communication error with switching module V" />
			<enum bytes="CF" text="Communication error with LON module" />
			<enum bytes="D1" text="Burner error" />
			<enum bytes="D4" text="Security temperature limiter has triggered or error reporting module incorrectly connected" />
			<enum bytes="D6" text="Error reported via DE1 on extension EA1" />
			<enum bytes="D7" text="Error reported via DE2 on extension EA1" />
			<enum bytes="D8" text="Error reported via DE3 on extension EA1" />
			<enum bytes="DA" text="Short room temperature sensor M1" />
			<enum bytes="DB" text="Short room temperature sensor M2" />
			<enum bytes="DC" text="Short room temperature sensor M3" />
			<enum bytes="DD" text="Interruption room temperature sensor M1" />
			<enum bytes="DE" text="Interruption room temperature sensor M2" />
			<enum bytes="DF" text="Interruption room temperature sensor M3" />
			<enum bytes="E0" text="Error external LON participant" />
			<enum bytes="E1" text="Ionisation flow too high during calibration" />
			<enum bytes="E2" text="Heat demand too low during calibration" />
			<enum bytes="E3" text="Heat demand too low during calibration - temperature guard switched off" />
			<enum bytes="E4" text="Power supply error 24V" />
			<enum bytes="E5" text="Internal error (ionisation electrode, flame amplifier)" />
			<enum bytes="E6" text="Exhaust/Air inflow system blocked or water pressure too low" />
			<enum bytes="E7" text="Ionisation flow too low during calibration" />
			<enum bytes="E8" text="Ionisation flow not within valid range" />
			<enum bytes="EA" text="Ionisation flow not within valid range during calibration (difference to last measurement too large)" />
			<enum bytes="EB" text="Flame extinguished too often during calibration" />
			<enum bytes="EC" text="Parameter eror during calibration" />
			<enum bytes="ED" text="Internal error (Replace control unit)" />
			<enum bytes="EE" text="No/too low flame signal at burner start" />
			<enum bytes="EF" text="Flame extiguished right after ignition (within the safety period)" />
			<enum bytes="F0" text="Internal error (Replace control unit)" />
			<enum bytes="F1" text="Exhaust temperature limiter has triggered" />
			<enum bytes="F2" text="Temperature limiter has triggered" />
			<enum bytes="F3" text="Flame signal already on on burner start" />
			<enum bytes="F4" text="No flame signal" />
			<enum bytes="F7" text="Differential pressure sensor broken" />
			<enum bytes="F8" text="Fuel valve closes too late" />
			<enum bytes="F9" text="Blower rotational speed too low on burner start" />
			<enum bytes="FA" text="Blower stand-still not achieved" />
			<enum bytes="FC" text="Gas combination regulator broken, wrong control of modulation valve or exhaust blocked" />
			<enum bytes="FD" text="Error in gas fire automatic/code plug missing (also error B7 will show)" />
			<enum bytes="FE" text="Strong electro-magnetic field (EMV) closeby or electronics broken or: codeplug wrong or broken or mainboard broken" />
			<enum bytes="FF" text="Strong electro-magnetic field (EMV) closeby or internal error or R-key blocked" />
		</unit>
	</units>
	<protocols>
		<protocol name="P300">
			<pid>41</pid>
			<macros>
				<macro name="GETADDR">
					<command>SEND 00 01</command>
				</macro>
                <macro name="SETADDR">
                    <command>SEND 00 02</command>
                </macro>
			</macros>
			<commands>
				<command name="getaddr">
					<send>GETADDR $addr $hexlen;RECV $len $unit</send>
				</command>
                <command name="setaddr">
                    <send>SETADDR $addr $hexlen;SEND BYTES $unit;RECV 2 SR</send>
                </command>
			</commands>
		</protocol>
	</protocols>
	<extern xmlns:xi="http://www.w3.org/2003/XInclude">
		<xi:include href="vito.xml" parse="xml" />
	</extern>
</V-Control>
