Kirjoittaja Aihe: F1245 uusi päivitys  (Luettu 3571 kertaa)
Poissa Henkkaua
F1245 uusi päivitys
« : 24.04.19 - klo:10:05 »
Terve vaan kaikille.
Huomasin, että nibeltä on tullut 18.4.2019 uusi päivitys koneeseen.
Onko kellään vielä kokemuksia uudesta päivityksestä.
Mielellään kuulisin niistä
Nibe F1245-8R+UKV100. tiiliverhoiltu 1 kerros talo -76 Rovaniemi. patteri lämmitys, 1 lehtiset patterit. takka. 113/138m2 . 180m porareikä
Poissa noble
Vs: F1245 uusi päivitys
« Vastaus #1 : 24.04.19 - klo:10:41 »
Version: 9172R2
Release date: 18/04/2019
Added
· Is now possible to choose “heat medium return (BT71)” on AUX-in (Menu 5.4)
· Alarm for pressure switch climate system added. Activates through AUX-input. Alarm number 165
“Low pressure climate system”. The alarm is a redlight alarm without control action but lights the
red diode and can give a notification through Uplink or SMS.
· Added a solution to problems scrolling in the menus. Prevents the display pointer from going back
and forth. This eliminates the need to replace the display unit due to this problem.
· Added possibility to set minimum allowed speed in heating for heating medium pump
· Now supports the accessory external energy
· Now supports master/slave function with Fxx55 models#NIBE * Extra climate system 2 - 8: It is now
possible to block the shunt on AA5-X2:13-14. When there is a connec- tion the shunt closes
· EME20: It is now possible to choose “priority household electricity” in menu 4.1.11 (Solar
electricity) if external energy meter is connected.
· New setting in menu 5.1.9 (brine pump speed), “Speed extern. contr (AUX)” by activating brine
pump on AUX-in.
Changes
· EME20: Improved communication with the accessory.
· Improved control of heating medium pump GP1
· ACS (active/passive cooling): Improved control
· Improved display of “my icons”. Prevents that part of the outdoor temperature is hidden when the
alumi- num door is closed.
· Minor adjustments of menues and texts.
· Solved incorrect names on climate system 2-8 in service info
· Improved control of the accessory HTS
· EME10: In the automatic search of accessories, EME10 could incorrectly be activated even though it
was not installed.
Oma on juuri pomppinut valikoissa, takuuta voimassa. Nibe antoi aiemmin ohjeeksi pyöritellä rullaa nopeasti muutaman kerran molempiin suuntiin, menee likaa ilmeisesti rullan taakse.
Ilmeisesti takuuseen on saatu uusia paneeleita, nyttemin ei enää jos tuo päivitys korjaa tuon pomppimisen.
Nibe 1245-8 / 180m kaivo
Poissa noble
« Vastaus #2 : 25.04.19 - klo:06:53 »
Päivityksen jälkeen valikkoon ilmestyi energianmittaus...  ::)
BF1 virtausmittari näyttää lukemia, mutta luultavasti arvot ovat puutaheinää. Ymmärtääkseni tässä koneessa ei ole virtausmittaria.
En ole nähnyt kuin arvon 5l/min kun kone on käynnissä.
Poissa Henkkaua
« Vastaus #3 : 29.04.19 - klo:11:40 »
Aika vähän ollu vielä kokemuksia päivityksestä.
Ilmeisesti mitään oikeaa parannusta ei ole tullut?
Poissa tk-
« Vastaus #4 : 01.05.19 - klo:22:21 »
Taitaa nuo invertterittömät pumput toimia siinä määrin hyvin jo aiemmillakin softilla, että tuskin kauheasti saadaan niistä enää päivittämällä lisää irti.. Toki uusin softa kannattaa aina pumpussa pitää, kun on niissä vähintään jotain bugeja aina korjailtu. Itsellä vielä päivittämättä kylläkin.
Poissa Henkkaua
« Vastaus #5 : 04.05.19 - klo:08:25 »
Laitoin uuden softan. En äkkiseltään huomannut mitään eroa tai valikkoja
