I have a Thermia Duo 12 (installed in Jan. 2004). There is a COM port on the control board and it is possible to connect a GSM modem there. In the "Service Menu" it is possible to configure the phone number and PIN code, so the heatpump should send the error messages as SMS. If you have seen the soldering iron before, then you can probably connect any computer to that COM port and listen for alarms. It must be possible to control the pump via this COM port (because this is done via Thermia Online) but I don't know how. I don't have any experience with Thermia Online.
Regards,
Jaak
