Mulla on Nibe F1245 vuodelta 2010. Nyt päivitin pitkästä aikaa ohjelmiston 7113R3:sta --> 7740R4 versioon. Mitkä ovat olleet tärkeimmät muutokset näiden versioiden välillä ja pitääkö mun päivityksestä johtuen käydä säätämässä jotain asetuksia takaisin ennalleen (onko jotain kenties resetoitunut)?
Yleensä päivitykset ei ole kajonneet asetuksiin.
MUUTOKSET
Version: 7113R4
Release date: 2016-02-03
Asennus: 12.3.2016
Changes
• Improved smart home functionality
• Improved control of circulation pump in FLM
• Now supports brine-pump Grundfos UPMXL
• Other minor bug fixes and improvements
Version: 7113R5
Release date: 9/2/2016
Asennus: 20.9.2016
Added
• Smart Price Adaption for Estonia Changes
• Improved function of brine pump speed
• Other minor bugfixes and improvements
Version: 7113R6
Release date: 9/30/2016
Added
• Support added for new type of memory circuit for the display unit.
This Update affects only upcoming displays with changed hardware.
Version: 7740R2
Release date: 11/3/2016
Asennus: 6.11.2016
Added
• Vacation can now be set in AUX-out (menu 5,4)
• Icelandic language added
• Now support accessory SES and OPT
• Now supports sensor BT57 and BT58 for the accessory ground water pump (AXC40) with the possibility to activate min out-temperature
• ”One time increase” is now optional in menu 2.1 (Temporary lux). When activating a temporary increase will start and stop when the need is met.
• Now supports accessory EME10
• It is now possible to choose EMK for slaves
• Now support accessory ERS10
• In F1145* it is now possible to choose hotwater charge method ”target temp” in menu 5.1.1
Changes
• Auto settings; start addition is now default 5 degrees
• Minor bugfixes and improvements
• Minor Adjustements of menus and texts
• Improved network stability
• Improved solar cooling function on Solar 40
• If country selection Belgium; the effect is now limited to 1electrical step. (0.5kW/1kW/1.33kW depending on the immersion heater)
Version: 7740R4
Release date: 11/30/2016
Asennus: 5.12.2016
Changes
• Solves a problem with the firmware v7740R2 that could not to be shown in menu 7.1 if update of an older F11/1245 with a display without Internet connection
